john
I have a 2002 wrx that starts to leak coolant where the radiator upper hose
is clamped to the radiator, after driving the car for 30 minutes on a
freeway. The coolant would drip on to the radiator and vaporize, causing a
burnt odor detectable from inside the car. This problem existed ever since I
bought the car.
The solution could be as simple as adjusting the hose clamp. But I want to
be sure it is not a more serious problem. Is it normal for the pressure in
the radiator to increase after driving 30 minutes? And when the pressure
increases, it is supposed to force some coolant into the reservoir (the
metal can with a radiator cap), then into the coolant overflow tank, right?
bought the car.
