Y
y_p_w
2004 WRX.
I opened the hood to check the fluid levels and found
leaves and pine needles resting on a part. Then I
noticed a completely severed wire. A later inspection
yielded a chewed cover over some ground wires - about 8
wires merged to the same connector bolted to the
throttle body.
Yep - it was a mouse.
The ground wires seem to be in decent shape. Only a
couple are exposed and I figure they can be easily
patched.
I don't know exactly how to describe the first wire I
noticed cut. It's located on the part just next to the
alternator - to the right when looking from the front.
The wire is gray with a plastic snap-in connector that
goes to a wire leading to the wiring harness. The
other end dissapears behind a plastic tab. Any idea
what this does and how this might be repaired?
I checked a local Subaru dealer, and they said the
wires were only available as a complete harness. If
there's more damage, I might just go to my insurance
company.
throttle body.
patched.
company.
