Check Engine light
R
Richard
I have a 1999 Subaru Outback Sport with about 80,000 miles. The check
engine light came on. I put the gas cap back on as instructed in the manual
and it went off for a while. Now it is back on steady. I had the catalytic
converter replaced at 59,000. What should I do?
converter replaced at 59,000. What should I do?]]
Crank that gas cap over tight several clicks six seven whatever. There
is something in the 1999 program that can turn that light on if you go
too fast, accelerate too quickly, eat a hamburger at Sonic, whatever.
Get someone to read the scan code and look up
what's wrong. There's literally 100's of
possibilities. If you can just get the scan
code, post it here and we'll look it up for
you.
If there is an Autozone near you go there and have them scan it, they
do it for free. Get the exact code in Pxxxx format, and post it here,
Without the code we really can't help you.
Richard,
Two of the Subaru's in our family have had to have oxygen sensor's replaced
in the past few years. Both had around 75,000 miles on them at the time.
This seems to be one of the most common reasons for the check engine light
coming on.
Jon
Jim Stewart said:
[CUT]
you.
My 2000 OB has two green connectors under the dash. When you need trouble
codes, you connect them and turn the ignition to ON (do not start the
engine). They supposed to flash the codes out (first digit, break, second
digit etc) with the check engine light or with the LED on the ECU unit
(supposedly, I only read about it on some forum, but I do have connectors,
just never used them yet). Anyway, Advanced Auto Parts stores also read
codes for free through OBDII or other diagnostic socket. All you need to do
is to lookup meaning of your codes somewhere. Hope this helps.
Marek K
Marek K
This method does not work on '96 and later OBDII vehicles. You can
retrieve codes this way on older OBDI cars, using the procedures here-
http://www.troublecodes.net/Subaru/
On OBDII cars the only way to retrieve codes is with a scanner.
Plugging the green connectors together does put the ECU into a
diagnostic mode but this is of no use to the average owner, no codes
are displayed. The check engine light will flash continuously and
various relays and solenoids will cycle.
I just went to AutoZone and they gave me the error code. Nice people. It is
"P1130 Fuel air metering" I looked it up on the website and it said "
Front oxygen sensor circuit malfunction (open circuit)". So I guess it
sounds like it has the same problem as yours. I have a couple of questions.
Do I have to get it repaired immediately? Should I take it to the dealer?
And about how much will it cost? Thanks Richard
AMARIAL
