Catalytic Converters
mrputler
My ’01 Forester with 78k miles is getting an intermittent CEL. Had it
in the shop for routine oil change and the code is pointing to the
catalytic converter. The dealer shop quoted $700 for the parts, $150
for labor.
Checking on line I’m finding catalytic converters for under $300 (for
both front and rear). Some of the brands I am finding are Bosal,
Magnaflow, Catco, DEC, and Eastern. Anyone have any experience, good
or bad, with non OEM replacements?
My 01 Forester with 78k miles is getting an intermittent CEL. Had it
P0420?
for labor.
Checking on line Im finding catalytic converters for under $300 (for
Search this forum for p0420. Some suggestions in that that would have
one think twice about aftermarket cat and o2 sensors.
I'm trying to solve this very issue on my vehicle as well.
for labor.
I've had two pair on non-OEM replacement CATS put on (for about $1100)
with better warranty (2 yr) than OEM (1 yr). Unfortunately the
CEL/code P0420 keeps coming back. All other angles have been checked
including replacing an 02 sensors. So as soon as the return details
are worked out on the non-OEM, I'll be getting Subaru replacements
front and back (for an additional $500+)
for labor.
Clear the code. If only one comes back, definitely try changing the
front O2 sensor. 78K would be early for a cat to go bad on a 'typical'
car. But not too early for an O2 sensor. order of magnitude difference
in price. Still, a GOOD shop should be able to scope the sensor and , if
good, flow test or tailpipe test for a bad cat. I suspect your dealer
would change both but 'say' the cat was bad. I 'might' be tempted to get
a second opinion anyway. Many people have had (is it 420?) cat
efficiency codes/w'ever and changed the sensor and been OK for another
80,000 miles. Do get the Subaru sensor though. Some folks have had
problems with aftermarket units.
Carl 1 Lucky Texan said:
Clear the code. If only one comes back, definitely try changing the front
O2 sensor. 78K would be early for a cat to go bad on a 'typical' car. But
not too early for an O2 sensor. order of magnitude difference in price.
Still, a GOOD shop should be able to scope the sensor and , if good, flow
test or tailpipe test for a bad cat. I suspect your dealer would change
both but 'say' the cat was bad. I 'might' be tempted to get a second
opinion anyway. Many people have had (is it 420?) cat efficiency
codes/w'ever and changed the sensor and been OK for another 80,000 miles.
Do get the Subaru sensor though. Some folks have had problems with
aftermarket units.
I agree. When my car was upgraded to a Stage 2, a high flow cat was part of
the package (aftermarket). It required a software upgrade to recalibrate
the cat efficiency and defeat the P0420 code. Many aftermarket cats and
sensors will cause it to be thrown.
Get your gaskets checked first.
I blew through several O2 sensors and had all sorts of indication my cat was
going bad before getting the final (bad) news that my head gasket was
leaking coolant into the exhaust. Which will also screw up the sensors and
throw errors.
ESPECIALLY on the 01 motors. So, look in the coolant tank while it's
running for bubbles, check coolant level, and get the coolant checked for
hydro carbons before throwing another 1k at a problem that might not be
that.
leaking coolant into the exhaust.  Which will also screw up the sensorsand
throw errors.
that.
- Show quoted text -
The head gaskets were checked at the last major service, and I don't
see any other indications that they are bad. The gas mileage hasn't
change (I'm getting 26 mpg in mixed driving) and it runs OK. I say OK
only because there is some rough running in low RPM in hot weather,
but otherwise it runs like when I bought it.
Like I mentioned, the light comes on intermittently. I've notice if I
drive from a big change in altitude, or if I fill up with a different
brand of gas, I'll get the light to come on. I also noticed that
after an air filter replacement the light stayed off for quite
awhile. Based on some of the comments made on the O2 sensors, I think
I'll replace those first and see what happens.
I'll relate my experience with a 2002 Forester, but I am not sure it
will shed any light on this phenomena.
At about 120000 miles or so, it started throwing 420 CEL codes. I
purchased a reader (BR-3:
http://obddiagnostics.com/), and, because it was wintertime
here in Wisconsin, I simply re-set the code. My reader also allowed me
to look at the raw sensor
voltage from the sensors, and at times, it seemed the rear sensor had
an intermittent connection.
I checked the rear sensor connector, but all looked good, but I kept
getting CELs (which I would clear)
Then, early this year, I purchased a new rear sensor, and replaced the
old one with it. Feeling good
about myself, I was sad to see the CEL return about 200 miles later,
and started to think what my next
fix would be. I re-set teh CEL, and kept driving. The car threw maybe
3 or 4 more more, sometime within 50 miles,
sometimes after 250 or so, and then it stopped.
So far, it has been 5000 miles or so since my last CEL. I do not know
if there is any 'burn-in' period for
new O2 sensors placed into service, but something happened to make the
code go away (for now).
I'm not sure there is a definite 'take-away' from my experience, but
there it is.
Thanks for your time,
Duane
there it is.
Duane
Did you change gas brands?
Possibly just the change from winter formula gas to summer formula
stopped the codes.
Some cars are fussy about their fuel quality - I know 2 hondas that
throw 420 codes whenever the vehicle is fueled with ESSO (Exxon) gas -
and NEVER with Shell.
Might have something to do with Ethanol concentration?
If so, changing the FRONT O2 sensor may be the fix. A rear sensor
problem would be much less likely to cause the 420 code.
stopped the codes.
Could be, I suppose. I am not sure how much the gasoline mixes change
here in
southern Wisconsin for the winter (I do know the diesel sold does).
BTW, here we
run 10% ethanol pretty much year-round.
Then again, one can never proclaim complete victory on a repair, until
one gets rid of the car....
This 2002 Forester hasn't shown any preference in fuels.
Perhaps. I based my diagnosis (replacing the rear sensor, not the
front), on the sporadically
erratic rear sensor reading, and the fact that driveability and fuel
economy had not changed (thus
making me think the front O2 sensor couldn't be too bad)
Duane
here in
BTW, here we
Duane- Hide quoted text -
I've been dealing with intermittent CEL with code p0420 for about five
years on my '00 outback. Between the dealer and my other shop, I think
I've been through 5 O2 sensors.
I have heard of other people with similar issues resolving it by
replacing a leaky y-pipe or y-pipe gaskets.
Is there a definitive test of the catalytic converter?
A couple of weeks ago, my daughter's forester threw the P0420 code
after I had replaced the front O2 sensor. It had thrown a code related
to that sensor a couple of weeks before.
Since it complained about "efficiency ratio", first replaced the rear
O2 sensor, figuring that maybe the rear O2 sensor was reading
something it shouldn't, but the 0420 code came back.
Since she had to pass emissions before the 17th to re-register, we bit
the bullet and changed the CAT two days ago.
The light stayed off and it was ready for emission testing yesterday.
It passed the test today.
Just to add this:
The front O2 sensor was definitely bad. It ran very rich causing it to
idle badly.
After I replaced the front O2 sensor, the mileage was again what it
should be.
Her car clearly had two problems, with the cat being bad as well.
It may have had a leak or something, causing the P0420 code. It is
hard to see with all the heat shields in place.
Remco said:
Just to add this:
idle badly.
should be.
If it had been running rich for a 'significant' amount of time, that is
very bad for converters. Add general age/condition issues and I would
not be surprised if 2 or all 3 components were bad/compromised.
That's what I figured as well. The O2 sensors were the easiest to
replace so did them first.
If you have a leak ahead of the converter you WILL have troubles. Fix
all leaks first.
A good indication of whether a cat is working is to check temperature
at the front of the converter and at the back. The back should be
hotter.
Just to add this:
idle badly.
should be.
A bad O2 semsor causing the engine to run rich will often overheat
and kill a cat.
When the CEL comes on, find the problem and fix it. Usually a lot
cheaper that way.
I had the 420 code, put in a new rear O2 sensor, and the CEL went
away. My mileage also increased from about 26 mpg to about 28 mpg. I
passed emissions a week later. Then about another week later the CEL
came back. It's been on for two or three weeks now, but I am still
getting improved mileage. I guess I need to go get the codes read
again. Hopefully the fact that my mileage is still improved means I'm
fine and the CEL is for another reason than a 420 code. Hopefully.
Sorry to burst your bubble, but a rear O2 sensor is a monitor only and
can not affect your gas mileage - period. ANd as stated before, a 420
code will not be solved by replacing a rear sensor alone. The front
sensor is more likely to be the culprit - or an actual bad cat. (which
would generally not pass e-test)
went through a incredible class a few years ago concerning rear 02 sensors
and fuel trim. Even tho the manufactured say it won't, or in some cases will
say "minorly" it can major effect fuel trim/gas mileage.
its the difference in what the tell you, and "us" the manufacture tech's and
what really happens.
Steve
