Mickey
A couple days ago I posted here about changing my converter. Received
assy and went about the install yesterday. The Converter is an
Eastern Catalytic brand PN# 40237. I first saw this brand a couple
weeks ago and didn't see them when I first started looking several
months ago. Close to $100 less than the DEC brand that has been
available for some time.
This converter is listed as a direct fit for several yrs and models
but it isn't a good fit for my OBW.
Going into the car the fit didn't look too bad but the hanger wasn't a
good fit. Not angled correctly and slot for hanger bolt not correct
size. Had problems with bolts so found the easy way to tackle the job
was to remove the head pipe. When I got the head pipes tightened back
up I noted the wiring harness on the front O2 sensor was hitting the
CV joint pretty bad. In addition to the above this assy come with an
extra O2 port but no plug provided or one found at several local auto
parts stores. What I had to do is weld the port shut.
At this point I'm still not clear if dealer, Auto Parts Warehouse, is
going to accept the return. Still working on this. Have also written
Eastern about the problem but no reply as yet.
Would advise anyone thinking about replacing their converter to steer
clear of Eastern brand at least until they make corrections so the
assy fits correctly.
Mickey
Mickey
