Hi Volleybiggs!
I have a 94 legacy with Tires that are 185/70R14. I saw a good deal on
some 05' Legacy Rims that are 215/45R17. Would I be able to just put
them on my 94 legacy? Or is the size to different?
Thanks!
No reason at all why you couldn't run 17 inch wheels on the older
Legacy. It'll look sharp. AFAIK, the newer Subaru wheels are the same
5X100 bolt pattern, and pretty much the same 35mm offset. Anyone out
there confirm this?
When you go to put rubber on the wheels, tho, you will want to pay
close attention to the tire size. The 215/45/17 tire is about 1/2 inch
taller, and an inch wider than the stock 185/70/14. A 205/45/17 would
be a better match.
This will make a _just_ noticeable difference as far as driving, and
probably won't present any clearance issues, About the only caution
would be in the vicinity of the lower spring perch of the rear strut.
This is the bottleneck as far as running larger/wider than stock tires
on most Soobies. Also, you may want a different spare tire to match
If you are buying the wheels with the tires on them, do try them on
first. If this isn't possible, try to estimate what effect the
additional 1/4 inch of height, and 1/2 inch of width will have. If
this gets the rubber uncomfortably close to the strut (say, closer
than 1/4 inch or so), proceed with caution. You can get wheel spacers
that will move the rim out the thickness of the spacer. They're not
expensive, but 1/4 inch is about as much as you can do before needing
longer studs. Also, Subaru wheels are hub-centric, so you will want
spacers that replicate the hub shoulder for best results.
And then you _do_ realize that low profile 17 inch tires are twice (or
more) the cost of the 70 series 14's . . .
Hope this is helpful.
