2010 forester broken timing belt due to idler bearing failure. Of coarse most of the valves are bent. I bought new valves,gasket set,head bolts,timing belt set.
While checking g the heads I found the right head has a broken cam shaft right under the center bearing cap.
Is this common? What might have caused this ?
New/used head is on its way.
