DDi
I have a 03 Forester MT with 170k. Replaced timing belt at 145k by my mechanic.
I noticed that sometime the car, when idling, was about 600-700 rpm. I drove cars with stick
before and was told it should be around 900rpm. So I talked to my mechanic. He said the the
best setting is low enough and not to get the engine stall. This way it saves gas when idling
before red light etc..
However I also heard that incorrect timing could cause air/gas mixture problem and might cause
unburn hot gas damage the catalytic converter. Right now I have a check engine light with a
code indicating that the Cat is no good.
I'm wondering, with the computerized control air/gas mixture in the car, does the timing
actually matter?
Would like to have the professional opinion about that.
Thanks in advance.
actually matter?
Thanks in advance.
