AWD light
H
houndman
the manual says that the AWD light will come on if different sized
tires were mounted or tire pressures were too far different. Does it
tell you when the center differential is working, like it would if one
axel was slipping?
VF
axel was slipping?
VF
It sounds like it is simply a warning light, advising you if some
condition (like those noted) could negatively impact the AWD system.
Dan D
'99 Impreza RS2.5 (son's)
Central NJ USA
Dan D
Central NJ USA
Found out it is Only on the Auto Trans models.((
VF
Staff online
summerinwa
