H
Hachiroku $B%O%A%m%/(B
3 speed AT, started slipping the other day so I checked the fluid; nothing
on the dipstick!
I added a quart, and it appreared at the bottom of the dipstick, just. Not
even to the LOW level. I added another half quart, and was at the low
level. Figured I'd drive it and see what happened. For the past two days
it's been puking ATF from the breather hose, at first regularly and then
intermittently.
How the heck do you check the ATF on this thing? Engine running in
neutral, or engine off? Hot or cold?
This makes twice I've added ATF and had it puke out the breather tube!
It's been running well the past few months (I filled it in January, drove
it till April, and then back on the road Nov 1.) As a matter of fact, the
tranny has until now been the best thing about the car!
I also used Castrol "Domestic Car" (Dexron-Mercon) ATF...I can't remember
what I used before!!
on the dipstick!
intermittently.
