AT Oil temp light flashing no codes in TCM.
2012 impreza 120k changed valve body (refurbished) about 2k ago fluid changed around same time. while driving AT oil light came on flashing with traction control light and abs light both are steady,paddle shifter and cruise wont work. double checked fluid level-full. connected aftermarket scanner fluid temp is normal no codes in ecm or tcm. please help. as I cant afford to go to dealer.
bobelsley
