Anyone know what this is?
I've been stalking the forum for years since buying an '06 Forester (2.5 AT) with 114K for my daughter. I've always been able to find the help I needed. . . until now.
I'm doing the TB and following the excellent advice found here like replacing all the pulleys and tensioner, front crank seal (yes, 2 of the oil pump screws were loose) and water pump. Disassembly went well and as I was doing the general cleanup I thought I was pulling on a piece of RTV but found I was pulling on this little foam strip. I removed the alternator and A/C bracket to get a better look but now I'm at a standstill. This is on the water pump side of the front of the engine. The engine has no problems with leaks and I want to keep it that way. It has a shape to it and looks like it is to keep dirt out of somewhere rather than fluid inside. Is it important? Should I try to put it back? Or should I just cut it off there and forget it?
Well I figured Subaru didn't just put it there for no good reason. As I looked at the old water pump I realized that whatever it was ran across one of the flat surfaces on it. I started taking things apart and found that it is some sort of gasket/spacer that runs along the bottom of the tensioner bracket and over to the oil pump. I RTV'd it in place and reinstalled the bracket. I torqued the three bolts on the bracket to about 21 ft.lbs with blue Loctite.
Does anyone know what the correct torque should be for the tensioner bracket and the A/C compressor bracket?
I found the same thing on my ej253 legacy. I figured it was something the factory used on initial assembly. I couldn’t find a parts reference for it. I left it out.
Jaxon
