All four tires loose air
2011 legacy, with front and rear tires filled to spec, after 2-3 days all have lost psi, from 4psi to 13psi. tires are 2 years old and have had my mechanic check them......no visible leaks. Could the psi monitor be causing this? thanx Dick
Hi Dick, I had the same problem with 2 of the tires on my wife's 2009 Forester. It turned out the valve stems were bad and needed to be replaced.
