ABS light
L
Lenny Kitching
Hi All,
New to group, hope you can help?
Replaced E20 engine in Legacy GT. All now running great but ABS light is
permanently on. Quoted £64 from dealer to just diagnose.
Is there any way of resetting ABS system to see if light clears? Fuse box
details in Japanese so I couldn't try fuse removal but did try battery
removal with no success.
Any advice would be greatly appreciated,
Lenny
Lenny said:
Hi All,
Lenny
Possibly broken wire to tone ring sensor?
I dunno
Checked voltage to be there at pump.
Now checking connections throughout system.
Anybody have a wiring diagram of ABS system for 1996 Legacy GT to help with
my checks?
Thanks
Don't forget to check the sensor at each wheel. I have seen/heard
where the sensor "wheel" has been broken when rotating tires.
All 'wheels' look intact.
I'm now almost totally convinced that the problem is a faulty sensor!
However, how I test for the culprit is a mystery. Guess I'll buy
replacements for both front and rear and try them on all wheels.
Thanks for the help.
If no more help here, ask over at www.ultimatesubaru.net .
