I am getting all three of these lights on every time I touch the brake pedal on my 2011 STI (Cobb intake, Cobb Fuel Pressure regulator). Resets after I restart the vehicle until I use the brake pedal again.
Here is what I have tried so far:
Replaced the brake light switch under the dash.
Reset the ECU
Stock Flashed my ECU (it was on a Cobb Map)
No DTC Codes (tried multiple scanners)
All three brake lights are functioning properly
I have done all of these at least twice, and in various different orders.
Problem began after I flashed the ECU for the stage 1 map from Cobb, but I confirmed that it is still there without the map installed or the AP installed.
I have scoured the internet for other solutions but the only other suggestions are steering wheel sensor or wheel speed sensor but I am skeptical.
I thought about a faulty wiring harness but the brake lights are working so again I am skeptical.
Reset the ECU
