4
4orrester
I recently had a problem with water in spare tire well of my '04 Forrester
that I had difficulty finding the source of. It didn't look like the hatch
gasket because it wasn't coming in anywhere near it - BUT...
The water was running down the outer edge of the gasket, then "wicking"
under it at or the point closest to the tail light. It then filled the
inner cavity of the gasket and ran down to the bottom where it seaped
between openings between the spot welds in the body panels of the
bottom-most edge. No water ever flowed between gasket and hatch or between
the gasket and inside edge - only under the gasket and into an opening where
it eventually found another seam abouth 1/2 way up the back side of the
spare well. Remove the inner plastic trim on the bottom of the opening for
an even better look. The problem was the poor sealant that was used, not
the gasket. Subaru used a white, non-hardening type of caulking to fill the
gasket before it was actually put on the car, but this material turns a bit
chaulky, shrinks and never actually bonds to either surface.
I pulled of the entire gasket, removed as much of the old caulking (not much
was used anyway) as I could from the gasket and car, cleaned all surfaces
with a little alcohol, then applied a generous amount of marine-grade
silicone. No more leak!
I never would have looked in the spare well to know there even WAS a leak
except that I was getting the car sprayed with "Rust Check". The guy asked
me if I wanted the spare well done...........you betcha............
One more thing - make sure you don't put the gasket back on with the soft
edge to the outside or you will have to take it of and do it again.
....ahem....
....ahem....
