randy.wells said:
I have a 2003 xs Forester, and on ruff dirt roads it is awesome.
However, not on uneven pavement or off road.
Sounds like you really do not need the turbo unless you want the
power and in that case get the five speed. The 2 liter boxer runs
really good and the automatic transmission is a dream. The biggest
drag is the cruise control; which will run the rpms up to 4000 and
stay there until you interrupt it. I know the car well any more
questions?
No problems at all with the cruise on my Forester. But I *have* been having
trouble with the transmission. Not mechanical problems, just difficulty
using it properly. I frequently miss 3rd gear when trying to shift fast.
(And I understand that the Forester isn't really a sports car, but if
they're going to sell the thing with a hot motor and a 5-speed, they ought
to at least make it a *decent* 5-speed.) I'm considering having the dealer
install a short-shift kit (if available) to see whether this will ameliorate
the spongy shifting. Furthermore, the ratio spacing is wierd -- the gears
are all way to close together and they're all to low. I only get about one
second of acceleration out of 1st gear before redline. And at 70 MPH in 5th
gear the tach shows almost 3500 RPM.
I noticed the tight gear spacing and low ratios on my various test drives,
but expected to get used to it. And I figured that Subaru wouldn't have
geared it that low unless the engine was intended to run at higher RPM's.
But I managed to avoid crunching 3rd gear until after I had actually
purchased my own. (Good for the dealer, I suppose, but not so much for me.)
I now have just over 6000 miles on it, and I'm still not completely used to
the funky gear ratios, resulting in occasional herky-jerky shifting --
though I seem to be getting there.
If I had it to do again, I'd fork over the extra bucks for an automatic,
just to save myself the frustration of trying to get used to this
transmission. And I'm not a novice with manuals. I've *always* preferred
manuals to autos when given a choice. Maybe I'm just getting old.
'Course I'm not so old as to not appreciate the turbo motor. I realize it's
not for everybody, but I wouldn't have even considered a non-turbo Forester.
But don't get the impression that I'm dissatisfied overall with the car just
because I'm having a hard time with the tranny. I still expect to keep this
car for a good long time. I'm just wishing that I hadn't made the
assumption that adjusting to the car's transmission gearing would be a snap.
Because it's turning out not to be.
- Greg Reed
