L
lpasco
PLEASE PLEASE PLEASE GIVE ME YOUR ADVICE AND OPINIONS
Ok i have a 1999 subaru forester with the 2.5l sohc engine. It has
79,000 miles on it and i just baught it a couple weeks ago. In the 2
weeks i noticed that it has blue smoke from the muffler. Now to me
that would be oil. I then checked the oil (had a oil change as soon as
i baught it with mobil one 5-30) with only 300 miles on it and i was a
qt low. I then added a qt of mobil one and drove it 150 miles. It then
was barly on the stick.
At the same time the check engine light came on. I scanned it and it
came up with miss fire on cyl 3. I changed the plugs and disconected
the battery to reset the code. i drove it and after one mile the light
came back. Scanned it again and it said miss fire cyl 3. I then
disconected the battery for 10 min and played with the plug wires
making sure there was a good connection with cyl 3 and started it and
drove it again. NO check engine light so far with 8 miles.
ok for the questions...... im going to get new plug wires tommarow,
but is this a common problem. i searched the old threds and this is
the only think i could find was a plug wire problem with other
peple....
2nd the oil part. I found another thread saying it was a common
problem and i would have to change the oil pump o ring and gasket? is
this true or is it proubably going to be cyl rings?
peple....
