E
[ evL ]
Hello folks, I have a problem, perhaps someone could help;
My 98' Outback wagon has the 'winter package'. With this package
is a switch next to the outside rear-view mirror adjustment 'joy-stick'
located to the far left of the dash-board. What this switch does
is de-frosts the outside rear-view mirrors. When you push the switch
in a little light on the switch lights up.
A couple of weeks ago I noticed this little light was dimly lit.
I push the switch in and it lit up brightly as usual. I thought
nothing of it. Sometimes it was lit and sometimes it wasn't.
The other day I am driving down the road and all the door locks
started locking and un-locking at the same time. I noticed the
door-timer relay was also clicking. Then the locks wouldn't work.
It used to be that with the key out of the ignition one could
select to lock or un-lock all the locks by using the switch on
either the driver or passenger door. This is not working now.
When I take the key out of the ignition all of them lock but then
the switches don't work. When I put the key in the ignition to
start it, they all lock as soon as the engine starts to turn over.
With the key in the "on" position or with the car running all the
locks work correctly with both switches. But of course now and then
they all start locking and un-locking on their own.
This I tell you is very freaky.
So here's the kicker. Now when I de-press the rear-view mirror
de-froster button all the doors lock. When pressed again they all
open. While this switch is pressed in none of the lock switches
work.???
Now I have checked all the fuses. I have a keyless entry box under
the dash and the two in-line fuses for it are good. I have never used
the key-less entry since I bought the car. I think there silly. Anyhow
I not only checked all the fuses to see if they were blown, I also
checked them for continuity. This was done to every fuse in the car.
Because none of the fuses are blown and the locks all work, the switches
work, I don't think I have a short. I am thinking a relay or who knows
what. It would seem a lot easier if the problem was just contained to the
door locks but with the de-frost button thrown in I am at a loss.
Any and suggestions would help, meanwhile I am going to start running the
multi-meter on everything.... This is a real bummer....
[ evL ]
work.???
[ evL ]
