D.Stone.Design
I have seen this posted before without a reply and would rather not
have my car towed If I can fix it myself.
My ingnition key will not turn in the lock. I have tried the usual
turning the wheel while turning the key, moving it up and down, etc.
Nothing works.
I have an Automatic. The manual says there is an override switch under
a cover in the steering column. I removed the cover but no sort of
switch can be seen.
If someone could tell me how to find this switch that would be great...
also if the ignition lock needs to be replaced, could this be done by
someone with a moderate amount of mechanical knowledge.
I may need to get some work on it anyways because the power locks will
only unlock and the pins are broken in the rear door so it can't be
locked or unlocked, but some help in the meantime would be great.
Nothing works.
switch can be seen.
