R
Hey -
I've got a 96' Legacy Outback that about intermittently won't start
(it happens about once per month). It only happnes when the car has
been sitting all day (ie the car is cold). It turns over perfectly
fine, but no pops or sounds of it trying to catch. Typically I walk
away for an hour+ and come back and it fires up fine with NO CEL light
(no light = no codes), and it runs fine for another month.
Nothing consistent weather wise... it's happened for 3 seasons now, so
I've eliminated cold/wetness.
Plugs, Wires, Fuel Filter, Battery (I checked the battery the other
day for giggles, 12V off, 14V charging, PERFECT) and crankshaft sensor
are all new... I also checked the resistance of the ignition coil (per
the Hayes manual) and it meets spec.
So, two questions:
(1 - the usual) Has anyone seen this before? If so, what was problem?
(2) Does anyone know what part of the ignition system is monitored by
the computer? AND more importantly, what ISN'T MONITORED? Does it
monitor the ignition coil? What about the fuel pressure? Since there
are no CEL codes, the problem is obviously in a place where the car
isn't looking... this way I can try to focus my attention.
-R
So, two questions:
-R
