S
SKCS, USN
Hello
I have a 1995 Legacy L Wagon with 120K on it, and, I started smelling oil
burning earlier this week. Nothing noticible from the top of the engine,
but, when I crawled underneath, I appear to have a leak on the front, bottom
of the engine---just in front of the oil pan. The head gasket on the top of
the engine is fine....in fact, there are no noticible oil leaks from the top
of the engine. What gasket is at the bottom front of the engine?? And, is
it pricey to replace??
I have no idea how long this has been leaking, since I just recently started
smelling the oil burning. I have no "oil spots" when I park the car. And,
my oil was just a little bit low.
Any idea on what gasket is leaking and replacement options?
Also----maybe it's just my luck, but, I've never had to put any money into
my Legacy (except routine maintenance), but, recently, along with this oil
leak, I have a laundry list of items that need to be repaired/replaced:
front brakes/rotors, rear struts, the solenoid on the starter is bad--so, I
need to replace the starter, the heat shield on the exhaust manifold is
rattling at idle, and my tires are worn. I guess once I had all this up,
it's not that bad...compared to the reliability of the car-----it's just
funny how all of this kinda happened at the same time.
Appreciate any help.....Thank you.....John
