B
Bradley Walker
This morning my mom got up and went to take her `95 Legacy out to do errands
and noticed when driving 3 miles up the road to the post office, a drip that
was leaving a visible fluid line on the pavement. When she got to the post
office, she noticed it was smoking pretty bad underneath the car and
immediately brought it back. At that point I went outside and noticed a 3'
wide puddle of oil/fluid on the driveway. I took some papertowels and
soaked up some of the oil noticing that it was red color which ruled out a
oil pan leak. That along with checking the engine oil showed that it was
still full. So I got to noticing that the smoke was coming from the rear
area of the block and I got to thinking if it was the transmission fluid.
Sure enough when I checked the transmission fluid dip stick it was a little
bit below L and had appearantly leaked most of the transmission fluid out.
When I looked under the car I noticed a visible dripping coming off of the
exhaust (explains the smoke) to a rate of about 1 big drip every 15 seconds.
I got to thinking, if this was a rear main seal, it wouldn't leak that much
fluid out in a period of 12 hours. Because last night when I had her car
out to go get a bite to eat, it was working fine in that no drips, no smoke,
nothing was happening. Whatever happened happened between 2am last night
and this morning. I called the dealership and they doubted it was the
tranny pan or the rear mail seal if it was leaking that fast. They said it
might be some fluid lines. Did something get tossed up under there while
driving last night that severed a line??
Thoughts, ideas??
Thoughts, ideas??
