CantAffordAMechanic via CarKB.com said:
I am trying to locate the throttle body and cables on my Subaru Loyale so
that I may spray wd40 on them. I know almost nothing about cars and need a
little help finding it.
Looking at the engine bay from the front, the air cleaner is in the box
on the left, with a large plastic pipe/hose leading to a rubber-looking
"box" in the center, which is held on with a very large hose clamp.
Loosen the clamp and lift the rubber "box" up (you MAY have to
disconnect another hose or two) and you'll be looking at the t/b and
linkage. You can get some spray t/b cleaner at the auto parts
store--it's for cleaning the interior (wash down the throat, let dry
before trying to start the engine) but also does a good job of cleaning
crud off the linkage. Then a drop or two of oil (not WD-40) on the parts
of the linkage that move (if you're not sure, have a helper push on the
gas pedal while you watch to see what moves) should do the trick. WD-40
will wash off a lot of crud, but doesn't leave you much residual
lubrication.
After everything's dry, put the "box" back on and tighten the clamp
securely. Engine should start now, though it might run rough for a
minute or so if any cleaner's still in the t/b. Watch carefully that you
got all the disconnected hoses reconnected and didn't knock any
electrical connectors loose. Should be a simple operation. If you don't
have one, this is a good time to spend a few bucks on a Haynes or
Chilton's manual! (IMO Haynes' pictures are more helpful if you're
really "lost.")
Good luck,
