Hi Mike!
the Driver's door look is not working properly. The key will not unlock
it and it seems to want to stay in the "locked" position. Sometimes I
can push the rocker into the unlocked position and it will stay there
ok. Is this an easy fix? Where do I start?
Not an "easy" fix, mostly because it's a b____ working inside of the
door on these cars. It helps to have small hands, and the patience of
Job. Find a short stool or plastic bucket to sit on while you
struggle, and a cold beer definitely comes in handy when you're ready
to throw things ;-)
You start by pulling the door panel and plastic liner. The door panel
is held by screws at the inside grip/arm rest (may be behind a foam
plug and/or a plastic snap-in cover), and around speaker grille. The
door handle surround is released by sliding a thin bladed scraper
(whatever) above and below the lever pivot, while prying the surround
outwards. You'll probably break the tabs anyway; no worries, it'll
still work. Then grab the panel at the bottom rear and pull outwards
to release several snap-in fasteners. I think that's all on the older
Legacys, but if it doesn't come away from the door easily, look around
some more for hidden fasteners. Undo the electricals from the power
window switch, and curb light if so equipped. The liner is held in
place with black-sticky; just pull it away carefully, and let it
dangle.
Disconnect the linkage to the key cylinder, and see if your key turns
it easily (a worn door lock is a common failure on Soobies with a
lotta use). If not, get another key/cylinder from a salvage yard.
FWIW, you will find it easiest to remove the entire outside door
handle (2 X 10mm nuts, but difficult to _see_, much less touch . . .)
to replace it. You might want to replace the ignition lock cylinder
with one that matches the new door key. To remove the ignition
cylinder, remove the plastic cover beneath the steering column (buncha
screws), turn key to "ACC" position, and insert a dental pick or
whatever works into the hole behind the cylinder. (And below? You'll
just have to look, or ask the scrapyard guy to show you where it is.
Much easier to see if the steering column is out of the car.) Press
the catch, and pull the cylinder out with the key. Turn the
replacement lock to "ACC", and insert.
If the door lock is working OK, see if you can determine if the
electric lock solenoid is what is pulling the latch into the locked
position (disconnect wires? disconnect linkage rod?). If it _is_ the
solenoid, can you live w/o the electric lock? If so, just disconnect
the wiring and/or linkage. Otherwise you will have to replace (IIRC)
the entire latch mechanism; again, try your friendly salvage yard for
the assembly.
Hope this helps.
