87 spfi flooding, error 14 (abnormal injector output)
A
aiiadict
hello,
I can drive forever if I keep RPM's below 4000
if I go above 4000, it will stall in a few minutes.
I figured out it is flooding. Restarting with gas pedal
floored (max air flow) starts in about 8 seconds of cranking.
info:
timing, valves correct
speed sensor : not connected
neutral switch: not connected
Any ideas?
Rich
@l77g2000hsb.googlegroups.com>,
info:
Reconnect the speed sensor?
I've driven it about 1000 miles now. It will flood any time
I floor it, or run it over 4000 RPM on the hiway. I'll try
reconnecting the speed sensor...
Rich
Moonpie927
