2.2 performance
Cost of a lighter crank pulley gets you nothing you can feel. Often over
looked is that the pulley is part of the flywheel effect that keeps the
engine smooth. eddie
andy said:
Any common mods to 99 impreza 2.2?
thanx.
andy
Do any of these "tuners" post results from their dyno. runs on their
websites?
I don't think any "bolt-on" mods will net much...you need to change
cams and/or go with forced induction.
It depends on what you mean by 'performance'.
It is unlikely you could get more than 10% improvement in power to the
ground with aftermarket mods. Those would include, intake, exhaust,
lightened pulleys, lightened flywheel. Some of those mods also come with
potential problems - CELs, ruined MAF sensors etc.
Now, chassis and suspension mods and better,possibly smaller, tires,
will make cornering much more fun.
check the forums at www.nasioc.com , www.i-club.com & www.usmb.net
1 Lucky Texan
I sure THINK I feel the difference....much more than I hoped for. There is
still a lot of rotating mass on the crankshaft...it revs faster at idle but
still has engine braking effect. This kinda depends on how you race/drive. I
should have mentioned the ground wire kits. Couldn't believe the difference
that can make. TG
vbwrx_mang
