Do you know where the thermal sensor is on the
transmission and is hard to replace ?
I'd rather get up to speed on the highway instead
of waiting 10 or more minutes for the trans to
get into the highest gear.
Not sure I understand the problem.
At different times I've owned both a '93 Imprezza and a '93 Loyale.
Both had 1.8 liter engines of slightly different design. Either one
would go directly from a cold start to 75 MPH on the freeway if I chose
to abuse them that way. The main difference is that cruise RPM on the
Imprezza would drop to around 3,000 after a two mile or so warm up. My
Loyale only had a three speed automatic and cruised around 4,300 RPM
regardless of engine temp. What exactly do you mean by "up to speed"?
If it's actually taking you ten minutes to get that final shift you may
have a bad thermostat. If it's stuck partially open the engine won't
warm up as quickly as it's supposed to. Also keep in mind that a 1.8
four cylinder doesn't burn enough fuel to make a lot of heat and the
Imprezza has a pretty large heater core. The thermostat only controls
what percentage of the coolant flow is routed through the radiator.
Here in Wisconsin I've seen winter days when running the heater blower
full blast would actually pull the temp gauge out the bottom of the
operating range on an engine that was already warm! :-(
Later,
Joe
