1986 GL Fuel Filter
Dan Da'Man
Does anyone know where the fuel filter is on a 1986 GL 1.8 Wagon?
Thanks in advance
Doc
Thanks in advance
Doc
Take a peek under your right rear wheel well. (Get it and my toyota's
locations mixed up unless I look, but think this is where I remember it
being).
Hi Doc!
2 of 'em; one under the car on the tray that also carries the fuel
pump (below the right side rear seat, more -r- less), and one under
the hood, drivers side, rear. They are different; so be sure to get
one of each. If you're having fuel delivery issues, also check the
pump while you're under there. Jumper the pump, and run a couple
gallons thru (into an empty gas can); delivery should be a good steady
flow w/o bubbles or surging.
Buzzingwickedly
