- Joined
- Nov 8, 2020
- Messages
- 9
- Reaction score
- 0
Hi, subies
I did a front end service on my '14 Impreza w/140K. It had at least one bad wheel bearing and I found a service kit that had wheel hubs, ball joints, tie rod ends, and sway bar links. Seemed like a good deal. Parts installed about how one would expect. Didn't end up doing ball joints cuz the factory bolt wouldn't even break loose and they aren't bad anyway, but the rest went reasonably well.
As soon as I started out the driveway to test drive it, dash lit up like a christmas tree and traction control started going bananas.
Pulled the driver's side off first and found that I'd bent the flange on the axle and it was hitting the ABS sensor; figured it's probably destroyed. Passenger side looked OK and I didn't butcher that flange.
I fixed the flange and reinstalled with the drivers' sensor disconnected which disables the ABS/traction control and unfortunately also sends the car into limp mode [lame IMHO]. I ordered a pair of cheap-o front ABS sensors and have installed them, but the computer still throws P500 codes and keeps the car in limp mode. I replaced the drivers' side first and had no improvement, then did the passenger and again no success. To be fair, the passenger sensor plug didn't want to go in and i had to really force it.
What I don't know is: Should I try higher dollar ABS sensors or could the wheel hubs be a problem as well? If there's no reason to suspect that wheel hubs could be the problem, I suppose I'd try another passenger sensor first. Clearly, it's one of those parts, since that's what was changed. I'm not really excited about spending any sort of money. There's a reason I do my own repairs, as it is...
I guess I'm just wanting to know if there are any little secrets, like multiple types of parts that all look and fit the same, etc. Any insight from people with experience would be appreciated.
