The driver's side automatic window switch doesn't work. All other windows work fine whether on the main panel or at each door. A friend removed the door panel and installed a new window switch panel on the door. Red glow lights, which were not before are now on but the driver's side window still doesn't work at all. Previous to replacing the switch, I had asked two different mechanics to check the fuses, but they didn't. I'm a 78 year old female. I only telling you all this because I suspect they can't hear me. I'm not a mechanic but I love my car.
I've been looking at YouTube videos. Some say it's because the battery died and was replaced, and it's a simple re-set fix. I can't find any examples of a driver's side window reset. Only passenger side. Also, where is the fuse? Where is the motor? Thanks!!!
