I think in the 'old days', folks would put a penny behind the lower
hinge plate to 'adjust' a door that was sagging.
I can feel the driver's door drop slightly on my wife's OBW. Not other
problems closing or opening it yet.
Is there 'correct' way to adjust this?
thanx
I don't know if the hinges on the 03s are the same as the 95s, but
when I put on a new door for my 95(first one rusted out at the
bottom.) I adjusted it by checking the gap at the back of the door,
then going for vertical alignment at the strike plate by keeping
either the top bolt tight and loosening the other three, then jacking
the back of the door up or down, then tightening, or by leaving the
bottom bolt tight and rotating around that one.
In your case, I'd suggest just leaving the top bolt tight, loosening
the other three, jacking the back of the door up a little, then
tighten the extreme bottom bolt, then checking for alignment and
tweaking from there. Hopefully the hinges do slide around on the body.
My Miata had pins that prevented that. I assume the pins are for crash
safety, and thus the 03 might have them whereas the 95 did not. Worth
checking into though.
Really not a bad procedure if you think through it as you go.
Bill
