B
BD
Hi, all.
I have a reasonably potent stereo in my WRX, and am noticing some
resonance in the doors and the dash at certain bass frequencies from
the speakers. The speakers are after-market. I'm pretty sure they're
not blown, and it's just a question of some bits of plastic 'buzzing'
when the tone hits the right spot.
I want to pull the door panels off, see what's rattling, and secure
it.
I went looking for instructions on removing the inner door panels, and
did find a post from awhile back (quoted below).
The point about removing the window control modules is not clear. Is
this suggesting pulling the toggles off the panel?
I wonder if someone could help to clarify the process here... I don't
want to pull on the wrong thing and break a clip somewhere.
Thanks!
BD
The front doors were very easy:-
- Remove electric window control modules, they pretty much just
unclip
from the front side first, then unplug the electrical connector .
Then
you will see a philips head screw holding the trim to the door.
- Remove the screw that you can see in the door handle (the bit you
open the door with) and remove that little plastic casing.
- From memory there were also another 1 or 2 screws hiding behind
plastic lugs in the arm rest.
After having done all that, if you gently pull the trim away from the
door, starting at the bottom of the door first, you will see where
the
plastic plugs are so you can sort of put your fingers close to them
when you pull the trim off.
The trim will pop off pretty easily, I think there are about 6 or so
plastic plugs.
When the trim is completely free, lift it un an upward direction and
it will slide out of the gap between the window and the inner side of
the door.
it.
Thanks!
BD
unclip
Then
the
plastic plugs.
the door.
