T
Tom W
Got an 2001 OBW 2.5 now with 118,000 miles. Now in its 4th winter. Last
year had BIG mileage drop off around December when temps got to be around 40
f. or less regularly. I am talking about a decrease from 25 MPG to around
16 MPG. No change in driving habits. Most mileage is daily 40 mile round
trip at about 70 MPH. Very little stop and go. Have used Mobil 1 since
beginning. Fuel filter, Plugs, Air Filter, PCV, Coolant and Oil all
replaced more often than recommended. Tire pressure is always about 2 PSI
over recommended (cold). Have changed thermostat twice. Heater output is
same as always.
1st 2 years of ownership, this did not happen, just last winter, and now
this. Last year mileage improved around April when things warmed up. Had
check engine light around June that dealer said was Knock Sensor and
replaced. Performance has remained consistent and it starts easy at all
times. No check engine light.
What can cause this last 2 years WINTER ONLY mileage drop off ? I know SOME
is to be expected, but this was sudden and drastic, last 2 years now (BUT
NOT 1st 2 years).
Can it be temp sensor (air or coolant) ? Mass flow sensor ? Suggested O2
sensors to dealer last spring and they said that was rarely a problem
(although I did not leave for service at that time).
Also have burned rubber smell from under hood when I park and get out, for
several months now, that I cannot trace. Now occasionally smell it inside.
Any help greatly appreciated.
Tom
same as always.
NOT 1st 2 years).
Tom
